slcohen61
#1 Posted : Monday, May 30, 2011 10:03:49 AM(UTC)
slcohen61
I have a Cabrio by Whirlpool washing machine. I keep getting a F1 code on the display panel. It stops in the middle of the cycle displays the code and beeps.
Any idea of what the problem is?
sidfink43
#2 Posted : Tuesday, May 31, 2011 4:55:32 PM(UTC)
sidfink43
Please post a model number so we can see exactly what you have.
In general on the Cabrio that error code indicates a primary board failure.
Also, there should be a tech sheet inside the machine under the top.
(Primary Control Failure)
F then 1 flashes when there is a primary control failure. Replace the machine control assembly.
DISPLAY
(Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
