The whirlpool duet wont turn on. Power okay. Microcomputer replaced and still wont turn on. Help 3 little kids need washer.
You need to add a Model Number. There are a number of different Duets
Also you are in the wrong forum, this is one is for dishwashers. You will still probably get a reply but have a better chance in the "Washer Repair" forum
Also add any other symptoms re: Is the unit totally dead? (no lights, no nothin) Does it do anything? Does it make any noise at all? Was any diagnostics done before replacing the control board? |
THIS FORUM IS DEAD!!!!!!! |
