Seems like when it's humid, water drips from above fridge door drips down thru fridge and accumulates on wooden floor (problem). Checked the water connect lines, seems OK.
Some of the solutions on similar problems talk about cleaning the drain tube, but that is in the bottom. Perhaps the drain tube is clogged and is filling up?
Any ideas?
JC
We have exactly the same problem. Did you ever figure out a solution? Thanks.
Turned out the condenser pan/tray which was made of plastic decayed and cracked, which caused water to leak out. There is a 'new' condenser pan made of metal which solves the problem. It took my repairman and I three hours of work to get the pan/tray replaced, we did the fan at the same time.
GE offered to pay for 1/2 the parts and labor because they know they have a problem. Thing is trying to get them to tell you this upfront is the other problem!
JC
Please contact me for more about what the GE Monogram refrigerator caused in my home. This model has known condensation problems and this unchecked water source causes mold to grow. This mold is very dangerous. I have the same model and it has caused $40,000. plus in damage to our home. Remove this refrigerator and see if there is mold growing on the wall. Please contact me for more info.
Originally Posted by: GE Hater  Please contact me for more about what the GE Monogram refrigerator caused in my home. This model has known condensation problems and this unchecked water source causes mold to grow. This mold is very dangerous. I have the same model and it has caused $40,000. plus in damage to our home. Remove this refrigerator and see if there is mold growing on the wall. Please contact me for more info. My GE Stainless Refrigerator is leaking at bottom. Appears to be a slow drip at bottom onto door hinge. The water dispenser tube is attached at bottom too. Could this be the problem and what to do about it? I pulled the refrigerator away from wall and I have mold on wall. Help!
