Kitchenaid oven. Top oven, left side interior light failed. Ordered bulb. Replaced it. (Lost the flippin' screw to hold in glass lamp assembly cover. ARGH!) New light bulb worked fine. Other three lights continued to work fine, as before.
Fast forward two to three weeks. ALL LIGHTS (both lights in top oven and both lights in bottom oven) failed. Not sure if this in an electrical issue or that when one lamp assembly (not just the bulb) fails, they daisy chain.
Before I order 4 new lamp assemblies (instead of just the one), please advise.
Also, how complicated is installing a new light assembly (WHIRLPOOL Part Number: AP3043766)? Homeowner-simple?
