gvernon
#1 Posted : Monday, May 30, 2011 6:02:58 AM(UTC)
gvernon
I have a seven year old refrigerator with freezer on the top, we leave it running in our cabin during the winter months with out heating the cabin and have never had any problems doing this, however this past winter the unit stopped cooling and freezing totally. It sounds like normal operation,the light comes on but it will not cool. is this unit history?:confused:
#2 Posted : Monday, May 30, 2011 6:34:20 AM(UTC)
Check to see if the compressor is running. You can usually hear it, also you should be able to feel it vibrating and it should be warm.
If it is running remove the cover inside the freezer so you can see the evaporator coils.
Check that the freezer fan is running.
If there is no frost or only frost where the freon enters the coils then it is a sealed system problem and probably not worth fixing as you need a pro.
Note: Be sure to check it after the compressor has run for a couple hours. If you check just after a defrost cycle there of course will not be any frost.
From your description of no cooling at all that is what it sounds likea sealed system problem.
But just in case your evaporator coils are clogged solid with ice/frost then you have a defrost problem and that should not be a difficult fix.
A model number would help if this is the case.
Warm Refrigerator - #HSS25GFTA WW (Refrigerator & Freezer Repair)
by Edwv30 5/5/2024 12:17:37 PM(UTC)
GE warm refrigerator, new inverter. (Refrigerator & Freezer Repair)
by Guest 11/24/2023 4:51:12 AM(UTC)
Freezer warm refrigerator cold (Refrigerator & Freezer Repair)
by oldfartsexpress 5/27/2018 8:34:46 AM(UTC)
Warm Refrigerator (Refrigerator & Freezer Repair)
by Just_me 7/17/2016 8:09:30 PM(UTC)
Warm Refrigerator, Cold Freezer (Refrigerator & Freezer Repair)
by phillb 2/27/2013 5:24:40 AM(UTC)
by mfjohnston 6/8/2012 2:31:45 AM(UTC)
Jenn-Air warm refrigerator section, freezer fine (Refrigerator & Freezer Repair)
by j34castro 7/26/2011 12:51:39 PM(UTC)
Warm refrigerator freezer OK (Refrigerator & Freezer Repair)
by jzielinski49@comcast.net 4/17/2011 8:54:53 AM(UTC)
warm refrigerator but freezer is fine (Refrigerator & Freezer Repair)
by bmt274 10/22/2010 10:38:10 AM(UTC)
Cold freezer, warm refrigerator (Refrigerator & Freezer Repair)
by dgandt 7/26/2010 11:16:32 AM(UTC)
Failing icemaker and warm refrigerator (Refrigerator & Freezer Repair)
by cshulamit 6/11/2010 7:52:44 PM(UTC)
by Nicholson 5/7/2010 10:08:33 AM(UTC)
by dnelsen 3/22/2010 6:23:19 AM(UTC)
warm refrigerator, frost on inside back panel (Refrigerator & Freezer Repair)
by mbnash 3/23/2009 9:44:19 PM(UTC)
Warm refrigerator (Refrigerator & Freezer Repair)
by jordad 3/23/2009 9:44:45 AM(UTC)
