Here's what it is DOING:
- WATER FILLS
- MOTOR RUNS
- AGITATES
- TIMER DIAL ADVANCES AND WON'T STOP (I manualy pull the knob to stop it.
- WATER WON'T DRAIN
- WON'T SPIN: WHEN DIAL ADVANCES TO SPIN CYCLE, IT WON'T SPIN, THERE IS A HUMMING SOUND
Can you diagnose the problem based on description above? What part do you think I need? Thanks, Florian
I would pull the cover off the timer and look for burnt points. If so, you need a new timer. The Whirlpool # is 660750. This sites # is AP2915208. Both sites I checked show it is no longer available. You can get this timer repaired. There are on line sites that do this, just crunch in google for them.
