The ice maker fill line that runs up the back of fridge is full of water it is not pumping up into maker to make ice anymore. I can fill maker with water and it produces ice. I need to know what that part is that pumps water into maker that the in line and out line are connected to.
My guess is the water line is frozen at the point it enters the freezer compartment altho the parts diagram doesn't show an ice maker with your particular model... Could be the ice maker was field installed after the refrigerator was first purchased... Suggest using a hair dryer to remove any ice buildup in the water line and if this condition persists then replacement of the water fill solenoid may be necessary... Look for any part numbers on the valve itself to help identify a replacement... Good luck, kooler
