drslgsr
#1 Posted : Saturday, May 28, 2011 12:14:58 PM(UTC)
drslgsr
The washer tub fills with water, but does not agitate clothes nor spins. It empties at the end of the wash and rinse cycles only. What can be wrong, and is it expensive to repair?
sidfink43
#2 Posted : Monday, May 30, 2011 4:03:21 PM(UTC)
sidfink43
Your machine has a diagnostic on the inverter, with flashing lights that indicate a code.
Here is how to interpret them.
HydroWave GE Washer Repair Guide
Try resetting the machine first with the instructions in the link.
My guess is your mode shifter will need replacing, but see what the codes say.
Whirlpool washer not spinning or agitating; blowing breaker (Washer Repair)
by ejditz3 8/4/2014 1:15:39 PM(UTC)
Kenmore washer not spinning or agitating, just "humming" (Washer Repair)
by dschar 10/25/2012 8:26:33 AM(UTC)
Washer not spinning or agitating (Washer Repair)
by jramirez1021 1/31/2011 8:04:19 AM(UTC)
washer not spinning or agitating again. (Washer Repair)
by bounette77 2/13/2010 5:18:45 AM(UTC)
washer not spinning or agitating but does everything else (Washer Repair)
by albarran61483 9/16/2009 5:46:13 AM(UTC)
