AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Kenmore washer not spinning or agitating, just "humming"
I have a Kenmore washer (#11020712991) that fills up but does not spin or agitate. The motor just hums like it wants to work but something's jamming it. I checked the motor coupler and that is fine. I also checked the pump to make sure that wasn't holding the motor up... it was fine too. What am I missing and need to check? Thank you for your help!
Groups: APP Team
Hi. First check the wire harness and connections from the motor and start capacitor to the timer and selector switch. Check the capacitor (you'll need a multimeter). The info is on the capacitor. Part number: 8572720
Post the results. Simon.
Washer Repair
