I have an electric range over 10 years old. The oven temperature is off by 50 degree and when I turn the little knob to set the oven temperaure it jumps, when I set it to go to higher temperature it jumps back to lower temperature.
sounds like the problem is in your LED clock timer this part is quite expensive...
How much is the LED clock timer? Is this something that we can fix or should we just call a repairsman.
