jillc
#1 Posted : Monday, February 9, 2009 4:32:11 PM(UTC)
jillc
I have an electric range over 10 years old. The oven temperature is off by 50 degree and when I turn the little knob to set the oven temperaure it jumps, when I set it to go to higher temperature it jumps back to lower temperature.
abbie
#2 Posted : Tuesday, February 10, 2009 4:05:19 PM(UTC)
abbie
sounds like the problem is in your LED clock timer this part is quite expensive...
jillc
#3 Posted : Saturday, February 21, 2009 12:36:36 PM(UTC)
jillc
How much is the LED clock timer? Is this something that we can fix or should we just call a repairsman.
