I have a Maytag Washer Model LA512. I recently purchased parts from you - WPL 215447, WPL 216201 & WPL 213015. I installed these, but "intermittently" as the tub is filling, water will overflow out of the white plastic section (these parts that I ordered make up the section I'm referring to), as if all of a sudden there's a blockage, or too much water coming through, or something. So, I'm wondering if you have any suggestions; i.e. could it be the water pump not regulating the flow of water properly? or ???? Just looking for some advice on this problem. The overflow is kind of random. I did 3 loads - no problem - then a couple of days later tried to do a load and after about 2 minutes of filling, it started to overflow. ?????? Sure appreciate any help on this problem.
Thanks, Debbie
The pump pumps the water out of the tub only. Have you tried reducing the pressure at the valve at your wall outlet?
