radarraden
#1 Posted : Monday, February 9, 2009 8:27:18 AM(UTC)
radarraden
I have a Maytag Washer Model LA512. I recently purchased parts from you - WPL 215447, WPL 216201 & WPL 213015. I installed these, but "intermittently" as the tub is filling, water will overflow out of the white plastic section (these parts that I ordered make up the section I'm referring to), as if all of a sudden there's a blockage, or too much water coming through, or something. So, I'm wondering if you have any suggestions; i.e. could it be the water pump not regulating the flow of water properly? or ???? Just looking for some advice on this problem. The overflow is kind of random. I did 3 loads - no problem - then a couple of days later tried to do a load and after about 2 minutes of filling, it started to overflow. ??????
Sure appreciate any help on this problem.
Thanks, Debbie
magician59
#2 Posted : Monday, February 9, 2009 11:12:50 AM(UTC)
magician59
The pump pumps the water out of the tub only. Have you tried reducing the pressure at the valve at your wall outlet?
