te4mundt
#1 Posted : Monday, February 9, 2009 3:29:15 AM(UTC)
te4mundt
my problem started 3 month ago. i started having a water dripping problem in the refrigerator section. then the cooling problem started with the refrigerator section. what do you think is the problem? what is the solution?
#2 Posted : Monday, February 9, 2009 5:35:25 AM(UTC)
Herte is your parts from AppliancePartsPros
Model FRT17B3AW3
Here is the parts breakdown and wiring diagram from Frigidaire
ftp://ftp.electrolux-na.com/Pr.../Anderson/5995379806.pdf
ftp://ftp.electrolux-na.com/Pr...F/Anderson/240379010.pdf
Sounds like 2 problems
The water down the back of the fresh food section is usually a clogged drain tube which runs down to the tray under the unit. This does indicate that defrost is probably OK (it is melting the ice off the evaporator coils).
Your problem may be just that the fan in the freezer is shot not.
To check for a defrost problem.
Remove the covers from the evaporator coils at the back of the freezer section. Check to see if the evaporator coils are not heavily iced over.
If they are you have a defrost problem.
Either the defrost heater, defrost thermostat or the defrost timer.
