turn3
#1 Posted : Sunday, February 8, 2009 6:41:53 PM(UTC)
turn3
I've tested the outlet and the dryer is getting power but will not work. The light isn't even coming on. Is there a way I can test the timer or push to start relay myself without calling a repair man.
#2 Posted : Monday, February 9, 2009 2:02:31 AM(UTC)
Model LER8620PW0
Here is the wiring diagram
https://www.servicematters.com/d...0Sheet%20-%203979703.pdf
How did you check the power?
The reason I ask is that you say the light will not come on.
I assume this is the interior drum light.
If it worked before and does not work now it is either the door switch is shot OR you have a power problem OR it burned out coincidentally.
If you just measured from L1 to L2 and got 240 volts, this does not eliminate a power problem as a cause. You also have to check L1 to Neutral and L2 to Neutral for 120 volts on each side. Your motor runs on 120 volts.
Turn the breaker Off/On a couple times slowly, sometimes you can loose Neutral without actually tripping the breaker.
