I've tested the outlet and the dryer is getting power but will not work. The light isn't even coming on. Is there a way I can test the timer or push to start relay myself without calling a repair man.
Here are your parts Model LER8620PW0Here is the wiring diagram https://www.servicematters.com/d...0Sheet%20-%203979703.pdfHow did you check the power? The reason I ask is that you say the light will not come on. I assume this is the interior drum light. If it worked before and does not work now it is either the door switch is shot OR you have a power problem OR it burned out coincidentally. If you just measured from L1 to L2 and got 240 volts, this does not eliminate a power problem as a cause. You also have to check L1 to Neutral and L2 to Neutral for 120 volts on each side. Your motor runs on 120 volts. Turn the breaker Off/On a couple times slowly, sometimes you can loose Neutral without actually tripping the breaker. |
THIS FORUM IS DEAD!!!!!!! |
