MJCALM
#1 Posted : Tuesday, May 24, 2011 10:02:30 AM(UTC)
MJCALM
Noticed small leak during fill cycle. Removed cover - no leaks found - all hoses & clamps dry. Started fill cycle - only water observed was small amount coming out of discharge hose when hose is at floor level. Is it normal for pump to pass small amount of water into discharge hose during filling, or is this an indication of faulty valve in pump? Before I schedule service on 22 yr old machine, trying to see if it's a possible easy fix. BTW, all other functions on washer normal.
magician59
#2 Posted : Tuesday, May 24, 2011 10:32:28 AM(UTC)
magician59
You might check the hoses for signs of wear; especially on the edges where they connect to the pump and tub/drain hose. If the pump is letting water through, there may be damage to the impeller. It isn't servicable; you'll need to replace it.
Part number: AP2907492
mikerita (Refrigerator & Freezer Repair)
by rita nesmith 3/24/2012 11:32:04 AM(UTC)
Mike (Oven Repair (including Ranges and Cooktops))
by lavish54 1/31/2012 7:46:38 AM(UTC)
Mike (Washer Repair)
by mjager4800 1/11/2012 7:15:42 PM(UTC)
Mike Menor (Dishwasher Repair)
by Mike Menor 12/19/2011 1:37:20 PM(UTC)
Mike (Dryer Repair)
by mrflv2bwl 12/5/2011 11:57:14 AM(UTC)
mike (Washer Repair)
by oldponi 11/19/2011 6:44:30 AM(UTC)
Mike Stewart (Dishwasher Repair)
by mstewart8840 10/20/2011 8:04:19 AM(UTC)
by 229526 8/22/2011 7:17:07 AM(UTC)
Mike s (Dryer Repair)
by mmshrader 1/27/2011 6:39:40 PM(UTC)
mike (Dryer Repair)
by mmshrader 1/27/2011 4:31:52 PM(UTC)
Mike (Dryer Repair)
by mrmc61@yahoo.com 6/12/2010 1:15:22 PM(UTC)
mike (Dryer Repair)
by mikelewistpt 5/26/2010 9:19:22 AM(UTC)
Mr. Mike (Dishwasher Repair)
by goodnurse 1/16/2010 8:54:09 AM(UTC)
mikeg (Refrigerator & Freezer Repair)
by mikeg1 12/21/2009 6:50:18 PM(UTC)
Mike Y (Washer Repair)
by myura46 12/21/2009 2:03:29 PM(UTC)
