rdharia
#1 Posted : Tuesday, May 24, 2011 6:39:08 AM(UTC)
rdharia
Does anyone know how to determine what is causing our Whirlpool refrigerator to drip water from the cold air duct under the freezer? I think it may be related to the defroster. Thoughts on how to determine cause?
#2 Posted : Tuesday, May 24, 2011 2:33:59 PM(UTC)
Sounds like drain tube is plugged so that the water from the defrost cycle cannot drain into the drain pan.
I would check that it is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tral after you are done.
Be sure to unplug the unit while doing this.
Water dripping from the freezer door and ice maker isn't working (Garbage Disposer Repair)
by thejipster 3/24/2013 10:05:11 PM(UTC)
