I can hear my gas dryer fire up and click on and off rapidly while I'm turning the dial to select the cycles. If I stop, the heat will come on without the drum rotating. Also, the dyer does not stop tumbling when I open the door.
What happens if you select cycles and options first and then start the dryer? If it keeps tumbling with the door open then the door switch has gone bad. - The part number for the door switch is AP2107703Gene.
