cropkween
#1 Posted : Thursday, February 5, 2009 4:52:30 PM(UTC)
cropkween
I can hear my gas dryer fire up and click on and off rapidly while I'm turning the dial to select the cycles. If I stop, the heat will come on without the drum rotating. Also, the dyer does not stop tumbling when I open the door.
#2 Posted : Friday, February 6, 2009 5:16:58 PM(UTC)
What happens if you select cycles and options first and then start the dryer?
If it keeps tumbling with the door open then the door switch has gone bad.
- The part number for the door switch is AP2107703
