kaykay
#1 Posted : Thursday, February 5, 2009 5:56:05 AM(UTC)
kaykay
This is a side by side. The freezer defrosted and the refrigerator is warm. I cleaned the coils. The compressor and the fan are running. The freezer is slightly blowing air but not cold...barely cool. And it is also slightly blowing air into the refrigerator...again not cool. I did not take the panel off the back of the freezer as any ice would already be thawed if it was ever there to begin with. I was thinking the thermostat under the control in the refrigerator. Please, what do you advise. Thanks, k
abbie
#2 Posted : Thursday, February 5, 2009 8:00:43 AM(UTC)
abbie
did you check the condenser fan to see if it,s working?It,s location is down by the compressor.If the compressor is working,so should the fan be working.check this ...
kaykay
#3 Posted : Thursday, February 5, 2009 8:07:04 AM(UTC)
kaykay
Hi and thank you.
I did check the fan and it is fine. Moving along just as it should. I am going to check the evaporator fan in a bit.
Refrigerator and freezer do not cool (Refrigerator & Freezer Repair)
by ssn 5/28/2011 3:15:46 PM(UTC)
