bosstone75
#1 Posted : Tuesday, February 3, 2009 6:52:00 PM(UTC)
bosstone75
I bought and installed this Kenmore Ultra Wash Quiet Guard 4 about a year and a half ago. Everything worked like a dream. Recently however, we've been having a problem when the dishwasher tries to fill it makes this terrible vibrating sound. As soon as the dishwasher is full, the vibrating stops.
Here's some things of interest....
The copper pipe that runs from just beyond the cut off valve to the dishwasher is slightly crimped in two places. (I reused the copper pipe from the previous dishwasher install) Could these crimps be causing the vibration?
I am able to stop the noise IF I use the cut off valve to the dishwasher to completely STOP the water from going in (while it's trying to fill) and then SLOWLY opening the valve up to full. I've tried all sorts of other openings and closings of various valves around the sink, but this appears to be the only fix.
Now, with all the monkeying around I've been doing, the connection from the copper pipe to the dishwasher seems to have sprung a bit of a leak. It doesn't appear to be coming from the connection between the nut and the dishwasher, but instead seems to be sneaking out behind the nut (between the nut and the pipe) So I'm thinking I'm going to have to replace that pipe anyway. If I replace the pipe, would it be ok to get a flexible metal one (do they make that? I know I have one on my toilet!)
My main question is... does this sound like it's a problem with the cut off valve? With the crimped old pipe? or with the dishwasher?
I may fix this myself or I may call in the troops depending on how difficult the fix sounds. If I decide to call in troops, would it be better to call a plumber? Or should I call Sears repair?
Thanks for any help or advice you can give!
Bill
bosstone75
#2 Posted : Wednesday, February 4, 2009 4:45:45 PM(UTC)
bosstone75
Turns out it was the valve. The valve was bringing air into the system which was causing the problems. Stopped by the local hardware store and picked up a new valve and a new hose and it runs like a dream!
#3 Posted : Thursday, February 5, 2009 4:13:22 PM(UTC)
Good job!
