carolb4
#1 Posted : Tuesday, February 3, 2009 10:01:12 AM(UTC)
carolb4
I have disassembled the ice maker down to the auger with the blades still attached. The end of the blades has a spacer and an oblong shaped metal bolt. How do I remove the blades so that I can replace the drum and auger?
I have read the other, from Gene (I think), replies about augers but none address how to remove the blades.
#2 Posted : Tuesday, February 3, 2009 7:44:29 PM(UTC)
This is a duplicated thread.
Answered here: http://forum.appliancepartspros...-remove-broken-drum.html
