I have disassembled the ice maker down to the auger with the blades still attached. The end of the blades has a spacer and an oblong shaped metal bolt. How do I remove the blades so that I can replace the drum and auger?
I have read the other, from Gene (I think), replies about augers but none address how to remove the blades.
