Dgrady121
#1 Posted : Monday, February 2, 2009 5:34:10 AM(UTC)
Dgrady121
The fridge will not automatically kick on. Sometimes I can make it turn on by manually turning the temp guage to off, then on again. When it does decide to start, it will only run for a few seconds and shut off.
What part or parts should I be checking?:mad:
magician59
#2 Posted : Monday, February 2, 2009 7:22:09 AM(UTC)
magician59
First check to make sure all the electrical connections are tight. it sounds like there is a loose connection, or a bad switch.
