how do I unplug wires from harness? there are 6 wires in harnes. sensor has 2 wires, I pulled one out and just the wire came out. dampner #ap3186598, sensor #242 My order#243084
Hi Tim
Are you going to replace the damper control, the sensor or both of them?
but I pulled one wire out of harness and can't put it back in harness. How can i put the wire back in, only the wire came out, the silver part is still in harness. I know now i could cut the wire and wire nut the new wires together. i can still do this to the one wire i did not pull out. and still have the first wire to deal with? Help
Tim
I'm afraid you broke the wire from the pin in the plug. If you can post a picture of the plug and wires, I might be able to help you fix it.
