tim connelly
#1 Posted : Friday, November 2, 2007 11:30:44 AM(UTC)
tim connelly
how do I unplug wires from harness? there are 6 wires in harnes.
sensor has 2 wires, I pulled one out and just the wire came out.
dampner #ap3186598, sensor #242
My order#243084
#2 Posted : Friday, November 2, 2007 12:18:58 PM(UTC)
Hi Tim
Are you going to replace the damper control, the sensor or both of them?
tim connelly
#3 Posted : Saturday, November 3, 2007 10:41:18 AM(UTC)
tim connelly
but I pulled one wire out of harness and can't put it back in harness.
How can i put the wire back in, only the wire came out, the silver part is still in harness.
I know now i could cut the wire and wire nut the new wires together. i can still do this to the one wire i did not pull out. and still have the first wire to deal with? Help
Tim
#4 Posted : Saturday, November 3, 2007 4:50:09 PM(UTC)
I'm afraid you broke the wire from the pin in the plug. If you can post a picture of the plug and wires, I might be able to help you fix it.
