I have a defrost problem (ice build up on evaporator over a few days). The refer never will go into defrost mode. I can jumper the Line and Defrost connector on the main control board and the defrost heater turns on. I changed the main control board and still have the same problem.
You may want to replace the evaporator thermistor (on top of the evaporator). This thermistor controls the defrost cycle. - The evaporator thermistor Part number: AP3185407
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You may want to replace the evaporator thermistor (on top of the evaporator). This thermistor controls the defrost cycle. - The evaporator thermistor Part number: AP3185407
Thanks for the help. Is it the FF Thermistor or the Evap Thermistor? And where is it located? Leonard
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...You may want to replace the evaporator thermistor (on top of the evaporator). This thermistor controls the defrost cycle... All thermistors in this refrigerator are identical. Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) All thermistors in this refrigerator are identical.
Gene. Problem is fixed. I changed the evap thermister and no change. Even after reinstalling the original computer. I then replaced the freezer and fresh food thermistor and now the referigerator will defrost by itself.
