JenB
#1 Posted : Tuesday, January 27, 2009 7:58:14 AM(UTC)
JenB
When I push the push to start switch it makes a hum but won't start. I used a voltage detector on all the wires and got nothing. So I replaced the thermal fuse but still won't start. But again I check with the voltage detector and only one wire isn't setting it off. It is a black wire that connects to the push to start switch. I would appreciate any advice.
#2 Posted: : Tuesday, January 27, 2009 8:35:10 AM(UTC)
Model LER5620KQ1
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208528187.pdf
Usually a hum is the motor running or the motor trying to run.
If the unit produces heat but the drum does not rotate then could be just the belt is broken.
For a motor not starting.
Rotate the drum by hand, it should rotate fairly easily. If not then you have a mechanical problem.
If it does rotate. With the door open and the door closed switch held closed, push start and rotate the drum in the correct direction. May take two people to accomplish this. Watch your knuckles in case it starts up.
If it does start this is a good indicator that your motor is shot.
Grampa Dave
#3 Posted : Tuesday, January 27, 2009 11:18:55 AM(UTC)
Grampa Dave
Couldn't it be a door switch problem?
#4 Posted : Tuesday, January 27, 2009 1:21:43 PM(UTC)
No
If you check the wiring diagram the door switch disconnects the Neutral, therefore the motor cannot get power.
The No of coarse assumes the hum is coming from the motor.
JenB
#5 Posted : Thursday, January 29, 2009 4:06:50 PM(UTC)
JenB
So I did what you said denman. It took two of us but we held in the door latch switch and pushed the start button and tried to rotate the drum. You can hear the motor start up and feel heat but the drum wouldn't turn. It is not the door latch or the push to start switch. The black wire is still not registering on the voltage detector. I took the top and the front off partly. The belt is still tightly on the drum. I didn't take it completely apart so I didn't see the motor but if you can see the belt snugly on the drum it should probably be fine right?:confused:
#6 Posted : Friday, January 30, 2009 4:11:33 AM(UTC)
Did the drum rotate fairly easily. It should
That the unit started to heat is an indication that the motor is turning.
There is a centrifugal switch on the motor that turns on power to the heating elements once the motor starts rotating.
Right. Should be but it is not.
Sounds like for some reason the belt is slipping on the motor.
You will have to remove the drum to find the cause.
Pay extra attention to the idler pulley!!
JenB
#7 Posted : Sunday, February 1, 2009 12:42:55 PM(UTC)
JenB
Ok so heres the story. I completely took the dryer apart. But the drum won't turn. The belt appears to be fine and located properly on the motor and pulley. Now there are some shavings on the bottom where it looks like the belt was rubbing on something wrong. But drum will turn if you rotate it but stops when you stop. I hate to ask could this be the motor? and if so is it feasible to replace it or cut my losses and get a new dryer?
#8 Posted : Sunday, February 1, 2009 1:40:34 PM(UTC)
Could be the centrifugal switches are actuated.
When the motor is at rest
Switch 1 connects the motor's start winding into the circuit
Switch 2 removes the heating element from the circuit.
When the motor starts to rotate
Switch 1 removes the motor's start winding from the circuit and the motor runs on the main winding
Switch 2 connects the heating element into the circuit and you get heat
Could be the mechanical assembly in the motor that actuates the switches is broken or jammed up with lint.
The drum will not spin very far if at all after rotating it by hand.
Sounds like it is rotating OK
Cannot tell where the shavings are coming from.
If they are metal something is rubbing where it should not
The motor is $81.86 not including shipping etc. from this site.
JenB
#9 Posted : Sunday, February 1, 2009 2:23:27 PM(UTC)
JenB
Also there is still a black wire that goes from the push to start switch down to the motor that has no power going through it. Any ideas? Could this be the actual problem?
#10 Posted : Sunday, February 1, 2009 2:49:19 PM(UTC)
Not actually doing the testing myself I cannot tell.
But looking at the tech sheet a black wire goes to the Start/Main centrifugal switch. What it does is provide power to the motor after the start switch is released RE: is in parallel with the start switch.
Holding the start switch closed will test this.
If it runs OK with the switch held closed then it may be the problem.
Guest (4)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Thermador oven won't start self clean (Oven Repair (including Ranges and Cooktops))
by beb123 2/6/2024 7:34:41 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Washer cycle won't start, motor just buzzes (Washer Repair)
by Guest 4/6/2023 4:46:53 PM(UTC)
Samsung DV42H5200EW/A3 Dryer makes loud buzzing noise and won't start unless (Dryer Repair)
by bvon 4/3/2023 9:46:22 PM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Samsung washing machine won't start (Washer Repair)
by Guest 11/14/2022 7:56:18 AM(UTC)
Maytag MDBH985AWS Won't Start Motor Humming (Dishwasher Repair)
by pdmac00 10/11/2022 12:48:23 PM(UTC)
Whirlpool WTW7500gc0 has power but won't start (Washer Repair)
by Guest 2/27/2022 2:52:51 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
dryer WED8300swo won't start (Dryer Repair)
by Guest 10/26/2021 10:24:13 AM(UTC)
Maytag LAT9600AAW Won't Start (Washer Repair)
by Guest 8/28/2021 6:11:33 AM(UTC)
