JAK321
#1 Posted : Thursday, January 22, 2009 4:31:06 PM(UTC)
JAK321
Potscruber lite keeps blinking. Then all the lights start flashing. Replaced controll board and reset all troubleshooting functions ,ran fine for first 2 washes and started doing the same thing!!!! HELP!
DBlood
#2 Posted : Monday, August 3, 2009 2:50:19 PM(UTC)
DBlood
"Adaptive wash" blinks back and forth with "Pots & Pans" and "Normal". Does anyone know how to reset this one? I bought it new 13 months ago. If I have to buy a new part I probably won't ever buy whirlpool again. Argh!
#3 Posted : Tuesday, August 4, 2009 12:36:41 PM(UTC)
Perform the troubleshooting as described in the Tech sheet.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU2700XTSS1 | AppliancePartsPros.com
DBlood
#4 Posted : Tuesday, August 4, 2009 3:18:43 PM(UTC)
DBlood
It's the control board. It appears that the ribbon may or may not be easily removable from the control board. Does it pull off and the new one push on?
#5 Posted : Tuesday, August 4, 2009 7:27:04 PM(UTC)
It can be "plug in" or "push in", I'm not sure about this particular model.
Whirlpool dishwasher WDT780SAEM1 (Dishwasher Repair)
by Guest 6/15/2023 1:10:41 PM(UTC)
Whirlpool Dishwasher Won't Advance Cycle (Dishwasher Repair)
by amappliancewi 3/28/2023 12:02:52 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool Dishwasher Wiring (Dishwasher Repair)
by Chitreano 6/21/2022 9:47:55 AM(UTC)
Whirlpool Dishwasher WDF520PADM7 Sanitized light blinking ***SOLVED (Dishwasher Repair)
by NC_OldGuy 5/20/2022 10:34:10 AM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Whirlpool Dishwasher: next steps to diagnose upper arms not spraying (Dishwasher Repair)
by erotenberg 1/9/2022 11:00:38 PM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
Whirlpool dishwasher drain issue (Dishwasher Repair)
by Bostomw 11/11/2021 3:54:47 PM(UTC)
Whirlpool dishwasher (WDF520PADM3) Cycle lights don't lit up (Dishwasher Repair)
by gowin09 6/13/2021 1:48:33 PM(UTC)
Whirlpool dishwasher door leak (Dishwasher Repair)
by Guest 5/26/2021 9:40:52 AM(UTC)
Whirlpool dishwasher - Replacing soap dispenser door? (Dishwasher Repair)
by NJGuy 5/17/2021 10:55:47 AM(UTC)
Whirlpool Dishwasher Intermittent Operation (Dishwasher Repair)
by Craigius757 3/12/2021 9:19:22 AM(UTC)
whirlpool Dishwasher WDT750SAHZ0 Leaking (Dishwasher Repair)
by Deanomich 10/15/2020 7:27:19 PM(UTC)
Whirlpool dishwasher shudders between wash/rinse and drain (Dishwasher Repair)
by aeb58DIY 7/6/2020 3:17:09 PM(UTC)
