AppliancePartsPros.com
Appliance Repair Help
Washer Repair
soap dispenser leaking whirlpool mfg.front load
water dribbles from tube (vent?) on dispenser when water is flowing thru. I have cleaned tray, but still no luck.
Originally Posted by: emzee water dribbles from tube (vent?) on dispenser when water is flowing thru. I have cleaned tray, but still no luck. Emzee, There is no vent tube. Did you remove the dispenser drawer and check and clean the bottom of the dispenser housing ? Is the washer level ? the next step would be to move the unit and disconnect the hoses at both ends, and clean the debris screens in the end of the hoses and on the inside of the fill valve. Let us know what happens, Good Luck :) :) :)
the tube is molded into dispenser, I assumed it was a vent. As you take off top it is visable on right side. I did not clean anything but tray, but I did not see any thing else inside. Do I remove it alltogether?
Originally Posted by: emzee the tube is molded into dispenser, I assumed it was a vent. As you take off top it is visable on right side. I did not clean anything but tray, but I did not see any thing else inside. Do I remove it alltogether? Emzee, Yes you need to completely remove the dispenser drawer, pull the drawer out as far as possible, press down on the retaining clip, and pull the drawer the rest of the way out. Once we're sure you have good water pressure, and no debris or clogs in the dispenser, we'll need to remove the top of the washer and check the fill tube from the dispenser to the tub for clogs/kinks and the water diverter assembly for proper operation. :) :) :)
I did have drawer all the way out and clean, I meant should I take out entire dispenser & clean it? Can it get partially plugged enough to cause leak from that tube? It is same dispenser used on Duet. I don't know what that tube is if not a vent. your help is appreciated!
Originally Posted by: emzee I did have drawer all the way out and clean, I meant should I take out entire dispenser & clean it? Can it get partially plugged enough to cause leak from that tube? It is same dispenser used on Duet. I don't know what that tube is if not a vent. your help is appreciated! Emzee, Usually if the vent tube leaks, it's due to a clog in the system, or and article stuck in the tub, usually something small andit's in the front tub area. So check that first. Here are the instructions for accessing the dispenser assembly, and what to check for as far as hoses and tubes being clogged/kinked. If you want, you can disconnect the hoses from the dispenser, you may want to soak it in a solution of very hot water and distilled white vinegar to remove any deposits that may have built up on/in the assembly. Removing the Washer Top
Three screws secure the washer top at the back of the washer. Remove the three screws and lift the top from the washer.
Removing the Console from the Cabinet
Disconnect the Touch Pad/LED Assembly ribbon connector from the left side of the Central Control Unit and release it from the wiring harness brackets on the right side of the washer top. Remove the detergent dispenser drawer by pressing down on the release tab at the back of the drawer
The Detergent Dispenser Assembly is located under the washer top. Begin by removing the washer top, console and front panel. Separate the water inlet and window washer tube from the boot. Pull the water inlet tube from the outlet connector of the detergent dispenser.
Check the inlet hose for clogs or debris.
NOTE: When reinstalling the water inlet tube, wet the water inlet gasket on the detergent dispenser with water only. Do not use any other lubricant. Align the locator nib on the water inlet tube with the indentation on the dispenser connector and slide the tube onto the detergent dispenser assembly. Remove the screw securing the front of the detergent dispenser assembly to the top front frame member Disconnect the vent tube from the detergent dispenser assembly. Remove the screw securing the detergent dispenser assembly to the top left frame member. Slide the assembly back slightly and lift the assembly out.
For what it's worth, I just finished replacing the seal and bearing in the drum and had the same problem: sprinkles of water were streaming out the front of the detergent dispenser. The solution was in making sure that the three hose inserts which are situated in the back of the dispenser inside the three hoses, are fully inserted into the dispenser. They direct the water streams to their proper destinations. Mine were not fully inserted, causing the water to stream and leak in small amounts out the front of the detergent dispenser. Hope this helps!
Originally Posted by: Robertoconsuerte For what it's worth, I just finished replacing the seal and bearing in the drum and had the same problem: sprinkles of water were streaming out the front of the detergent dispenser. The solution was in making sure that the three hose inserts which are situated in the back of the dispenser inside the three hoses, are fully inserted into the dispenser. They direct the water streams to their proper destinations. Mine were not fully inserted, causing the water to stream and leak in small amounts out the front of the detergent dispenser. Hope this helps! Roberto, Thanks for your update and information. It should be helpful and handy for future reference. Thanks Again.
Washer Repair
