Jcrane
#1 Posted : Wednesday, April 27, 2011 10:58:13 AM(UTC)
Jcrane
I was not careful in attempting to remove the unit from the window and it fell. Fortunately it was cushioned by a bush. In the fall, the thermostat knob brokd and the wire from the plug came loose. I was able to piece it back together without knob control function and it appeared to work fine. I am not sure what level the thermostat is set at an cannot control the setting due to the damage. I have two questions:
1. a ground wire also came loose and I am not sure what it is to be connected to. Does the thermostat require a ground?
2. can I get a replacement part?
icehouse
#2 Posted : Friday, April 29, 2011 4:33:12 PM(UTC)
icehouse
Yes to both questions just supply model number. :)
Jcrane
#3 Posted : Sunday, May 1, 2011 2:41:39 AM(UTC)
Jcrane
There is no obvious ground connector on the thermostat. Any tips on how to connect the ground?
icehouse
#4 Posted : Sunday, May 1, 2011 7:13:35 AM(UTC)
icehouse
To either mounting screw and then to chasis of A/C
