I was not careful in attempting to remove the unit from the window and it fell. Fortunately it was cushioned by a bush. In the fall, the thermostat knob brokd and the wire from the plug came loose. I was able to piece it back together without knob control function and it appeared to work fine. I am not sure what level the thermostat is set at an cannot control the setting due to the damage. I have two questions: 1. a ground wire also came loose and I am not sure what it is to be connected to. Does the thermostat require a ground? 2. can I get a replacement part?
Originally Posted by: Jcrane  I was not careful in attempting to remove the unit from the window and it fell. Fortunately it was cushioned by a bush. In the fall, the thermostat knob brokd and the wire from the plug came loose. I was able to piece it back together without knob control function and it appeared to work fine. I am not sure what level the thermostat is set at an cannot control the setting due to the damage. I have two questions: 1. a ground wire also came loose and I am not sure what it is to be connected to. Does the thermostat require a ground? 2. can I get a replacement part? Yes to both questions just supply model number. :)
There is no obvious ground connector on the thermostat. Any tips on how to connect the ground?
Originally Posted by: Jcrane  There is no obvious ground connector on the thermostat. Any tips on how to connect the ground? To either mounting screw and then to chasis of A/C
