Hi all. I've just replaced my motor and got everything back together. I hit the start button while looking underneath and water started leaking badly from around the drain pump.
I didn't see an o-ring when taking it off, but it looks as though there should be one. I removed it, checked for debris, and reinstalled it, but the leak persists.
Any ideas?
Thanks.
It's fixed.
The o-ring had come off of its seat and partially slipped under the plate of the impeller. I reseated it correctly and everything's fine.
