Baldrick
#1 Posted : Tuesday, April 26, 2011 1:37:10 PM(UTC)
Baldrick
Hi all. I've just replaced my motor and got everything back together. I hit the start button while looking underneath and water started leaking badly from around the drain pump.
I didn't see an o-ring when taking it off, but it looks as though there should be one. I removed it, checked for debris, and reinstalled it, but the leak persists.
Any ideas?
Thanks.
Baldrick
#2 Posted : Wednesday, April 27, 2011 10:19:16 AM(UTC)
Baldrick
It's fixed.
The o-ring had come off of its seat and partially slipped under the plate of the impeller. I reseated it correctly and everything's fine.
Maytag Washer Drain Pump Leaking (Washer Repair)
by Divelucaya 2/2/2011 1:02:10 PM(UTC)
