greghzl
#1 Posted : Tuesday, April 26, 2011 1:10:33 PM(UTC)
greghzl
My oven is geting to hot and the door is locking and giving code E2 F3 Have replaced the oven temp sensor still doing the same thing.
#2 Posted : Tuesday, April 26, 2011 3:15:08 PM(UTC)
Check the oven sensor wire harness to the control board. Eliminate the sensor quick disconnect plug and hard wire it using a high temperature porcelain wire nuts. If it would not help, replace the oven control board.
- The porcelain wire nuts Part number: AP3440631
Oven Over Heating (Oven Repair (including Ranges and Cooktops))
by LeesaBennett 5/8/2013 11:43:54 AM(UTC)
Oven over heating and locking door (Oven Repair (including Ranges and Cooktops))
by mfender 1/11/2013 9:47:23 AM(UTC)
oven over heating (Oven Repair (including Ranges and Cooktops))
by don_chan 1/5/2013 6:56:42 PM(UTC)
Oven over heating (Oven Repair (including Ranges and Cooktops))
by Bob Lewis 11/29/2012 10:03:32 AM(UTC)
by pigg74 2/6/2008 6:17:14 PM(UTC)
