wulff26@live.com
#1 Posted : Tuesday, April 26, 2011 5:45:36 AM(UTC)
wulff26@live.com
my gibson washer will go through the cycles but won't spin? What should I do?
sidfink43
#2 Posted : Wednesday, April 27, 2011 7:02:45 AM(UTC)
sidfink43
Inside the lower service panel is a set of tech notes. Use the info to test the door lock asssembly and the speed/motor control board. Those are your likely problems.
RANDY NEAL
#3 Posted : Wednesday, June 1, 2011 7:11:17 AM(UTC)
RANDY NEAL
Where Is The "lower Service Panel" ?
Front Or Back Of Gws645rfs0?
Washes Fine, Drains, But Does Not Spin.
sidfink43
#4 Posted : Wednesday, June 1, 2011 8:51:24 AM(UTC)
sidfink43
RANDY NEAL
#5 Posted : Wednesday, June 1, 2011 9:23:56 AM(UTC)
RANDY NEAL
Originally Posted by: sidfink43 Go to Quoted Post
mine in a top load washer, with 2 phillips head screws at the bottom .
is this it?
RANDY NEAL
#6 Posted : Wednesday, June 1, 2011 9:28:29 AM(UTC)
RANDY NEAL
is this it?
your model # is incorrect.
model = GWS645RFS0. THANKS
sidfink43
#7 Posted : Wednesday, June 1, 2011 11:55:42 AM(UTC)
sidfink43
Ok, take out the two screws and the front will pull out. You can now watch it is spin mode and see if the motor is turning or it is not. See also if the transmission pulley will turn.
