my gibson washer will go through the cycles but won't spin? What should I do?
Inside the lower service panel is a set of tech notes. Use the info to test the door lock asssembly and the speed/motor control board. Those are your likely problems.
Where Is The "lower Service Panel" ? Front Or Back Of Gws645rfs0? Washes Fine, Drains, But Does Not Spin.
Originally Posted by: sidfink43 mine in a top load washer, with 2 phillips head screws at the bottom . is this it?
Originally Posted by: RANDY NEAL mine in a top load washer, with 2 phillips head screws at the bottom . is this it? your model # is incorrect. model = GWS645RFS0. THANKS
Ok, take out the two screws and the front will pull out. You can now watch it is spin mode and see if the motor is turning or it is not. See also if the transmission pulley will turn.
