The fill water is clean. Once the machine starts agitating brown scum shows up in the water. I have cleaned everything inside the washer that I can reach without taking it apart. I have cycled through with clean water and bleach several times. Have removed and cleaned the fabric softener dispenser and cup under it. I am still getting brown scum floating in the water (which eventually ends up on clothes). How can I remove the agitator to clean under it?
Is the scum oily and hard to remove from clothes? Remove agitator by removing the screw near the bottom. Check it and the tranny nut for oil and post results.
