Bubbasmom
#1 Posted : Sunday, October 28, 2007 5:46:34 PM(UTC)
Bubbasmom
The fill water is clean. Once the machine starts agitating brown scum shows up in the water. I have cleaned everything inside the washer that I can reach without taking it apart. I have cycled through with clean water and bleach several times. Have removed and cleaned the fabric softener dispenser and cup under it. I am still getting brown scum floating in the water (which eventually ends up on clothes). How can I remove the agitator to clean under it?
#2 Posted : Monday, October 29, 2007 2:59:21 AM(UTC)
Is the scum oily and hard to remove from clothes? Remove agitator by removing the screw near the bottom. Check it and the tranny nut for oil and post results.
