The washing cycle does not function. It pumps water in and out but skips the wash cycle on more than one choice of cleaning. How do you determine if the problem is the Electronic Control? How do you get to it to replace it?
You will have to pull the inner panel off to get to the control module. Disconnect motor plug and press the latch to turn dishwasher on and select the failing cycle. If no voltage to motor, you have a bad control module. You will need the service sheet to find the right pins on the control module.This is located behind the bottom kick panel.You have a two wire sidewinder motor without a start relay so this makes things simple to check motor voltage.
