I replaced the rear electronic panel board (your # AP4010046) in January, 2011. It had a black-spot on it. After installing your new part it worked fine, but has not stopped working again. I looked at the rear panel board I had replaced and it looks fine. When you touch the fan button it beeps but nothing happens. I do not know what to do next. Thank you for your help. :)
Open the control panel and remove the membrane switch ribbon cable from the control board. Check for continuity between the ribbon cable contacts 5 & 7 while the Fan pad is depressed. If the reading is incorrect, replace the control panel. - The control panel Part number: AP4088736
Gene, Thank you very much for replying to my request for help with my Jenn-Air range. You suggest holding down the fan button while I check power. Can you please tell me what the ohms readings should be on the panel unit I am checking? Thank you, billasher
Sorry for the delay.
The normal reading should be about 0 Ohms.
Sorry, Gene: Are you saying it should read 0 ohms while pressing the fan button?
Many thanks, billasher
Yes, that's correct.
