billasher
#1 Posted : Thursday, April 21, 2011 11:06:21 AM(UTC)
billasher
I replaced the rear electronic panel board (your # AP4010046) in January, 2011. It had a black-spot on it. After installing your new part it worked fine, but has not stopped working again. I looked at the rear panel board I had replaced and it looks fine. When you touch the fan button it beeps but nothing happens. I do not know what to do next. Thank you for your help. :)
#2 Posted : Thursday, April 21, 2011 1:41:11 PM(UTC)
Open the control panel and remove the membrane switch ribbon cable from the control board. Check for continuity between the ribbon cable contacts 5 & 7 while the Fan pad is depressed. If the reading is incorrect, replace the control panel.
- The control panel Part number: AP4088736
billasher
#3 Posted : Friday, April 22, 2011 5:49:32 AM(UTC)
billasher
Gene,
Thank you very much for replying to my request for help with my Jenn-Air range. You suggest holding down the fan button while I check power. Can you please tell me what the ohms readings should be on the panel unit I am checking?
Thank you,
billasher
#4 Posted : Tuesday, April 26, 2011 1:15:08 PM(UTC)
Sorry for the delay.
The normal reading should be about 0 Ohms.
billasher
#5 Posted : Wednesday, April 27, 2011 5:20:02 AM(UTC)
billasher
Sorry, Gene: Are you saying it should read 0 ohms while pressing the fan button?
Many thanks,
billasher
#6 Posted : Wednesday, April 27, 2011 1:50:14 PM(UTC)
Yes, that's correct.
Guest (5)
