Hi All, Please see attached photos for detailed areas with issues. 1. First is the leak. I thought it was coming from the gasket area below my arrow but it is actually coming from bottom of tub area... see red arrow - It's a good heavy leak too 2. I noticed that the agitator in the tub wasn't spinning when clothing was placed in the tub full of water. It just squealed and ran very slow. I thought it might be the tensioner.. see arrow in second picture. But I could be wrong. I can rebuilt a V8 but I don't have a clue how to fix the above or what parts I might need. Any help would be greatly appreciated. Cheers :) 4evrmoor attached the following image(s):
I cannot get your model to come up, and will not be able to if it is a laundramat type or a foreign model. I think you leak is the seal, and your other problem may be water in the transmission, but hard to say. Here is a link to a service manual for the basic Frigidaire top loader, hope it helps. http://www.emaservicetips.com/pdfs/489_5.pdf
