paul12truck
#1 Posted : 14 years ago
paul12truck
frosted on back. not keeping things cold in freezer or fridge. I am thinking defrost heater, and timer?? Or just one of them. anything else?? Is it easy to find and replace these? Or should I call a tech?? Help , my food is getting warm!!
#2 Posted : 14 years ago
Replacement parts for rsw22e0cae models | AppliancePartsPros.com
[COLOR="DarkRed"]am thinking defrost heater, and timer?? Or just one of them. anything else?? [/COLOR]
Could also be the defrost thermostat.
[COLOR="DarkRed"]Is it easy to find and replace these?[/COLOR]
Depends what you mean by easy but it is definitely not rocket science.
If I can do it then odds are high that you can.
[COLOR="DarkRed"]
Or should I call a tech??[/COLOR]
Only you can know that. If you have a little mechanical ability and the motivation and the time I would try to fix it yourself. It will cast less than half what a repair tech will charge you.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 20 in Section 9) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 36 in Section 9) from the wiring and measure it for continuity, usually around 20 ohms or so.
The heaters in your unit look like the glass type and they have a reputation for blowing, Often you can actually see where they burned out.
If the heater is OK
Remove one wire to the defrost thermostat (Item 29 in Section 9) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
paul12truck
#3 Posted : 14 years ago
paul12truck
thank you so much for your advice!
paul12truck
#4 Posted : 14 years ago
paul12truck
where exactly is the defrost timer? I see a black box with wires coming out of it, located below the freezer compartment , screwed to the divider between freezer and fridge. But the parts photo shows it is white?? Am I looking in the wrong spot? thank you.
#5 Posted : 14 years ago
Not sure where it is.
They are usually behind the front kick plate or at the back of the unit.
The color does not matter but it will be the same shape.
Also the parts shows a mounting bracket, it has a hole in the center so you should be able to see and adjust the timing cam.
The cam is made so a screw driver can only turn it in one direction (has ridges on it)
Click on the picture of the timer to get a better view of it.
