jasonhart1
#1 Posted : Sunday, April 17, 2011 9:39:11 AM(UTC)
jasonhart1
My Kenmore stacked washer/dryer,the washer will only work if the dryer is running. But it will only fill up with water and then it won't wash or do nothing. But I can turn the knob,to the spin cycle it drain the water out. I can't figure it out. Can, someone please help me. Thank you
sidfink43
#2 Posted : Monday, April 18, 2011 3:31:59 PM(UTC)
sidfink43
If you post a model number someone may be able to help you.
In the meantime see if there is a wiring diagram behind the console and if so see if you can trace out the wires and find the problem. I assume that the machine works fine if the dryer is on.
Kenmore Stackable Washer/Dryer Lid Switch (Washer Repair)
by C@TCH 3/6/2017 3:27:14 PM(UTC)
Kenmore stackable washer/dryer won't drain or spin (Washer Repair)
by penelope therese 3/20/2013 6:26:11 AM(UTC)
kenmore stackable washer/dryer (Washer Repair)
by karns7 6/7/2011 8:01:26 AM(UTC)
Kenmore Stackable Washer/Dryer not drying clothes (Dryer Repair)
by tamisjoy 12/17/2009 10:06:04 AM(UTC)
