stick64
#1 Posted : Wednesday, January 14, 2009 6:40:21 PM(UTC)
stick64
The front dispenser plaque for selecting ice,crush,water,light, etc............. has one of the selections worn through. Is it as easy as just peeling the old one of and replacing with new front plaque ?? thx
#2 Posted : Thursday, January 15, 2009 4:05:43 AM(UTC)
Could find no info using given Model Number
Could it be a KSCS27QFWH00
Here is the link to that unit
Model KSCS27QFWH00
It may be a bit of a search to find one.
I have not done this but it looks like it is a peel and stick.
If it is unplug the unit and use a hair dyer to heat up the panel.
Often heat will loosen up the glue.
Once the old panel is removed clean up any glue residue with isopropyl alcohol.
Some glues require using varsol / mineral spirits.
stick64
#3 Posted : Thursday, January 15, 2009 6:53:42 AM(UTC)
stick64
:) Thx, that is it. AP out of stock currently.
