The front dispenser plaque for selecting ice,crush,water,light, etc............. has one of the selections worn through. Is it as easy as just peeling the old one of and replacing with new front plaque ?? thx
Could find no info using given Model Number Could it be a KSCS27QFWH00 Here is the link to that unit Model KSCS27QFWH00It may be a bit of a search to find one. I have not done this but it looks like it is a peel and stick. If it is unplug the unit and use a hair dyer to heat up the panel. Often heat will loosen up the glue. Once the old panel is removed clean up any glue residue with isopropyl alcohol. Some glues require using varsol / mineral spirits. |
THIS FORUM IS DEAD!!!!!!! |
:) Thx, that is it. AP out of stock currently.
