Model rud4000mqo can not get hot water or heat to dry dishes, heating element is good , is there a fuse that protects the blower and element. Bill
Could not find any info using the listed Model Number. Are you sure it is not a RUD Here is the link to RUD4000MQ0 Model RUD4000MQ0Take a look at Fuse Item 26 in the "Pump and spray arm parts" section. |
THIS FORUM IS DEAD!!!!!!! |
