underachiever
#1 Posted : Monday, January 18, 2010 2:45:13 AM(UTC)
underachiever
Dishwasher not heating water for hi-temp wash or sanitize cycle. Also element not heating up for drying cycle. Replaced element but still not working. Any suggestions?
#2 Posted : Monday, January 18, 2010 3:03:58 AM(UTC)
Replacement parts for FRIGIDAIRE GLD2250RDQ0 Frigidaire/dishwasher | AppliancePartsPros.com
Here is a tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154526501en.pdf
Did you check the hi-limit thermostat?
underachiever
#3 Posted : Monday, January 18, 2010 7:24:22 AM(UTC)
underachiever
No I have not checked that. Can you provide the part number for the hi limit thermostat? Is it the one under the tub? There is also something called a thermister.
Will appliance parts pro allow me to return the heating element I just ordered? That was not the problem.
#4 Posted : Monday, January 18, 2010 1:27:15 PM(UTC)
[COLOR="Blue"]Can you provide the part number for the hi limit thermostat?[/COLOR]
Part number: AP2109201
Item 29 in Section 3
[COLOR="Blue"]Is it the one under the tub?[/COLOR]
Yes
[COLOR="Blue"]There is also something called a thermister.[/COLOR]
It measures the temperature. I am not sure whet it's resistance should be.
Perhaps someone lse can provide that info.
[COLOR="Blue"]Will appliance parts pro allow me to return the heating element I just ordered? [/COLOR]
I do not know.
But I would get a meter so you can check parts before ordering them.
